36 PWK
Who can tell me which bikes came stock with a 36mm PWK Air Striker with a 91mm body?  That is want I am wanting to try on my 03.
I know that 1998 KX 125's came with a 91mm length 36mm PWK AS1 carb.  The 99-00 kx125's used the newer AS2 75mm  PWK's. I would assume all of the twist top 36mm AS1 PWK's are 91mm in length.
Edited by rtv
I tried to find exactly what you are looking for this spring... with no real luck, I went ahead and bought a new PWK36 from PJ Motorsports.
I never did get the increased throttle response or boost in low rpm power that I was hoping for going from 38 to 36 (07 Cr250)... just different jetting numbers and slightly better fuel mileage. Good luck
for a little cheaper than it would cost to buy a new 36mm PWK carb, you could get low/mid porting from Eric Gorr, which would probably give you better results.
Edited by frdbtr
Thanks for the info DanBot. I can get a 38 $100 cheaper so I will stick with that if it doesn't help the low end.
