Power Cutting Out On 06 crf250r
So I just had my timing done professionally, as well as valves. Everything should be in spec but the power cuts out when you are accelerating hard. I know that i am not on the rev limiter. I had the same problem as this before I had my timing and valves done. My timing was off one tooth. That's fixed now. Could my valves be too tight? If so the shop didn't do them properly. Could it be jetting? I really have no idea. Any thoughts would help thanks guys.
Might not be the timing after all. Is your carb ok? Float level ok? Jets clean? Fuel tank's gas cap venting system isn't plugged up? Petcock's screen filter not plugged up? Fuel flowing to carb? Spark plug old/fouled, try a new one yet?
Edited by Eddie8v
