PLEASE HELP!
Thanks to everyone that reply's my brother in law just got a mint 1984 xr250r when we got the bike the guy that sold it said that the motor was fully rebuild witch is fine. so here is the problem that i need help with the bike runs and starts great. the bike shift's into first and secound but when it comes to third gear you need to tap the shifter lever with your foot to the right then shift up to forth and so on till 6th its almost like you need to knock it into gear or something.if anyone can help with this issue that would be great thanks.
Firstly, be sure the shift lever isn't loose on the shaft.
How much play does the shift shaft have in and out.
I think I would secure the bike on a stand, start it up and run it thru the gears by hand instead of a booted foot, to make sure it isn't just a problem with feel of your booted foot, especially since the bike is new to him.
tighten the sgifter still same problem i need to tap on it for it to go into next gear, i even tryed to shift it slower still never worked.
