450 cutting out back firing.
Hey guy my 450r is doing this thing where it will idel fine and you can puut around on it with no problems but soon as you give it to her it cuts out and it's not like it bogs down it's like it's not firing. Any suggestions. Thanks
It's an 03 and I cleans the carb and jets. And drained the tank and cleaned the little filter in the tank. I do a lot of sand riding and the carb had some in it so I thought that could be the problem but it wasn't. Could it be the fuel to air ratio or maybe bad gas?
Hello, did you have the slide out of the carb? it sounds like the vacuum release plate is upside down. The flatter part of the plate with a slight cut out in the middle goes down.cheers
No I didn't have the slide out. But everything ran fine until I parked it for a week then I went to ride it and it started acting up.
