Shifting issue's help!
Thanks to everyone that reply's my brother in lawicon1.png just got a mint 1984 xr250r when we got the bike the guy that sold it said that the motor was fully rebuild witch is fine. so here is the problem that i need help with the bike runs and starts great. the bike shift's into first and secound but when it comes to third gear you need to tap the shifter lever with your foot to the right then shift up to forth and so on till 6th its almost like you need to knock it into gear or something.if anyone can help with this issue that would be great thanks. i also made sure the shift lever is tight on the bike and everything the shift shaft as minor play in it.
