12' crf250r wiseco problem
put on the wiseco basket and the wiseco clutch pack kit on my bike today. the clutch kit comes with 8 fibers and steels (OEM is 7 fibers and steels). so i put the eight in just to add to bitting force. with eight the clutch will not disengage all the way and lurches like a grooved basket. i tried the 7 which is oem and the clutch wont engage. ( clutch out i can bang through the gears with nothing) also put in the PRO-X clutch rod with it. So is this a common problem and i have to run the eight plates and adjust the clutch cable all the way so it can disengage fully? also have a new clutch cable as well, just have to put it on.
thanks for any help, Matt
Edited by Matt Honda 86
Did you install the OEM judder spring or just the plates/steels that came with the Wiseco kit?  Did you compare the Pro-X clutch rod against the OEM to make sure they are the same length?
