2009 Crf450r will not start.
2009 CRF450r. The bike will not fire up. Valves in spec. Timing is dead on, chain doesn't have slack in it. I pulled the fuel pump and checked it today. Brand new fuel filter. Bike is getting spark. When I kick it, my killswitch will partially light up every 20 or more kicks. The last time I went riding, It took several more kicks than usual to start, with my throttle knob pulled out. I was running a wiseco fuel controller but it has been removed. Again the bike is timed right and is getting spark. Any help will be appreciated.
Try cleaning all the connections and checking the air filter is clean. I've found, as well as alot of other blokes on TT the 09 is very temperamental with old fuel. I also moved my earth wire from the rad to a spot with more metal contact and found it helped ( I like to think it did anyway )
You could check your stator aswell
Edited by Aus450
