2007 klx250s motard conversion issues
Anyone else had these issues? What were the solutions?
My bike is a 2007 klx250s
I did consult the forums before I decided to go with the tires I did. From what I read other people have done this mod without mods... But... Here is what I have:
Just installed stock hubs, Buchanan spokes and 17x4.25 warp9 rear rim with 150/60r17 tires. On the front stock hub, Buchanan spokes and 17x3.5 warp9 front rim with 120/60r17 tires on the front.
Rear clearance issues... Rear tire touches chain. Has anyone had that issue? Is there an offset rear sprocket I should use? Is there a front sprocket with an offset as well?
Front clearance issues on the disc side the tire doesn't clear the upper fork tube.
Anyways... Just curious if any of you have had the same issues and what you did to fix them.
Thanks,
Graham
You can "dish" your rear wheel by loosening one side, and taking up the slack with the other. Search for it on youtube
