Honda 1987 Honda TRX70 fuel tank
I need a fuel tank for the above mentioned 1987 Honda TRX70.  All I can find is the aftermarket plastic ones.  I'd prefer to get an OEM metal one.  Anyone on here have one?  Or know of any good salvage websites that I might be able to contact to see if they can track one down?
Look if you want a metal tank unless you are rebuilding it for a display model you want a plastic one!!Todays fuel that has alcohol, oxygen, etc. it will kill a metal tank unless its coated inside!!! So if youre fixin it to ride go with a plastic and save yourself a ton of carb and engine problems. besides even a new trx tank if you find one should be coated inside!!!
