96 yz 250
Not sure if I'm posting in the right section. I got a 96 yz 250 that runs great but does not tune right. I need some advice
We'll it runs great. Just did brand new seals and gaskets. The carb is the issue. It has the choke as my idol adjustment. The air mixture screw does nothing right now
If I adjust the choke screw it makes the bike idol and runn great but it idols very uneven like it's to lean
Replace your pilot jet and clear the passage above it
Drop you slide to the bottom, drop you air screw to one turn
Turn in the idle screw till it starts to idle
Raise the idle with the AIR SCREW
Ok yea I think I may have to change the pilot. The needle is already dropped. Should I go alittle richer on the pilot
