Easy and cheap fix for leaky pipe joint...
I'm sure others have done this, but maybe some other YZ newbies like myself will see this post. Permatex hi temp silicone (I used red) seals up the often leaky yz pipe joint perfectly. Just clean up both ends of your pipe joint and the little rubber boot thing with some contact cleaner, and goop some on the mating parts. It is also easy to re seal if you need to take the silencer off for maintenance.
