valve seat machining question
if you get your head machined, wouldn't that mean that the specs in the oem manual for shimming would be off? seeing as you took material away from the head, the valves would sit farther into the head meaning you'd actually need bigger shims than what the manual calls for in order to get the correct valve clearance?
