NEED HELP! Metal in oil
Hello Fellow DRZ owners and TT'ers,
I'm worrying at the moment!
Bike info:
- Currently has 23000 kms
- I have owned it since it had 9000 kms
- oil and oil filter changed every 1000-1500 kms
- All locktite fixes have been done
- used 90% road 10% off-road. And off-roading was on road tires...
-Air filter cleaned every 5000 or so kms
-Original owner left the ACCT on.... I replaced the cam chain and installed MCCT
- valves checked every 5000 or so kms. Always in spec... never needed adjusting.
- bike was lightly crashed between now and the last oil change
So here is the problem....
Today I went to change the oil again, however this time I decided I would check and clean the oil sump screen FOR THE FIRST TIME EVER. Below is the screen I am talking about (after I had cleaned it already).
Problem is I found a shit load of aluminium shavings and bits in there. As can be seen below:
10615681_702739526463673_482031032_n.jpg10647587_702739559797003_1419562515_n.jp10634188_702739586463667_1269888430_n.jp
There was also a few similar sized pieces in the oil pan after I drained it.
So the question is... wtf is this and what do i do?
Unless you have a catastrophic failure, I wouldn't look at that screen its takes a lot to clog it,  and all that could be from original breakin.
I know on mine , second oil filter change I had a large sliver of aluminum, I don't even now how it made it through the oil ports to make it to the filter, it was so big.  No telling what I had in that screen never bother to check it.
I have one more minor problem....
I found two extremely small (Think 1mm long max and skinny) steel peices stuck to my magnetic sump plug.....
Is that something you would worry about?
Edited by YourPalsChrisAndAl
