400 exc to 450
Ok geniuses!!! I have heard of people changing a 400exc rfs over to a 450. What does it take to do this? I have an 06 450 sx rfs and want to put a 400 crank in it. Does anyone know of a piston for this swap? Thanks! V.
The time honored method of converting the 450 RFS to a 450 is with a big bore piston.
Why would you want to put a 400 RFS crank in a 450 SXF RFS?  Since the stroke is the same or at least very similar the only gain might be extra crankshaft weight (inertia).
To anyone interested, this is how it's done. You must use the 64mm full circle crank (not the sx pork chop crank), along with a 95 mm 525 cylinder and you must use a proprietary Wiseco piston that is only available from Thumper Racing. The piston number is 9631m09500. You must also lentghen the timing chain. Good Luck! V.
Edited by vidarapido
