Does anyone no easy instructions to change a drz400 swing arm bearings or a instructional video ?
im currently in the process of replacing my Linkage bearings, im using the method the Clymer book explains on how to do it, this is to have a long threaded bolt that fits between the bearings, a socket of a similar size to the bearing itself and then a socket the same size as the outer "housing" or hole in which the bearing slides out into to. also used a bunch of washers to keep it all flush. heres a picture (sorry for bad quality, was taken on a phone and couldnt find an online version of the book >.>)
Did you follow the link I provided? And READ the article titles SWINGARM MAINTENANCE? .. It's a tech article about...........Maintaining the swingarm...
If that does not answer your specific question, or you need someone further explained, just ask,, lost of folks will help if they know specifcally what you need.
