1992 RM 125 front forks.
My forks squirted oil out of this tiny hole is this normal? i was stripping the bike as frames been sent for powder coating as i was taking forks off one slide up more then the other one and revealed a tiny hole and oil pure out of it? please help me ?
thanks
Damper rod has come unscrewed from top can I'd suspect...
Sent from my iPhone using Thumper Talk
If this is the case how do i fix it? or is it a goner?
Undo the fork cap and check out if anything is broken..
Hi KB, I've taken them apart and there was something that had came apart it was the springy rod thing and when it went up and down oil came out so i put that back on seems fine now i lost a fair bit of oil though :( that side seems very spongy now is it because its lost oil? how would i top up this?
thank you
Yes .. Because you lost the oil most likely.
I'd drain out what's left , rinse out with a small amount on mentholated spirits or contact cleaner, then refill to standard oil quantity.
If you have the ability I'd completely disassemble the fork and completely clean and inspect, change seals and bushes.. But that's your call!!
BTW.. After filling the fork with oil, cycle the inside rod up and down through its travel till the dampening feels consistent ( no air pockets within the cartridge)
ok thanks I've not got the tools to completely take apart :( all the seals are good from what i can see no leaks. where do u pure the oil into? is it soon as u take the cap off and u see the damper rod?
Remove cap and spring.. Then add oil, if that's how you want to repair it.
I'd completely disassemble it and clean out properly, YouTube it., you will learn something !!
