xr600 lower oil drain bolt stripped, how do i remove it?
title says it all. i went to give it a fresh oil snf filter change and could only remove the upper oil drain bolt, also i could not undo the allen head bolts holdibg the oil filter cover, they just want to strip out. any ideas? thanks fellas.
Vice grips on the heads ,otherwise sometimes you'll need to cut off the head and once the cover is off you use the vice grip on the bolt shank. Cutting is a last resort and need to be done carefully , very carefully . Put new bolts back in and don't crank them down as tight anymore. They only need around 7-10 in/lbs torque.(for 6mm)  Put a new o-ring in the cover so it seals without needing to be overtorqued.
The main drain bolt in the case, vice grips or a nut welded to it. Get a new magnetic drain plug and sealing washer, torque properly.
Edited by jjktmrider
hey thanks alot, i will probably have to get someone to weld a nut on it cause its a tight spot for vice grips but i will give it a try anyways. the previous ownermust have thought he was supernan cause every bolt is over tightened, like i cant even get the front wheel off right now cause the bolts too damn tight and i dont want to strip it also. well thanks and have a great day
  • Similar Content
    • By XR-CJ
      I have this issue several times and cannot seem to figure it out. The four clutch spring bolts are the weakest bolts I have ever come across. I am not sure what the torque specs are, have the shop manual, have searched online and I can only guess it's around 4 ft/lbs. I have been told 8 and they seem to break every time around 7.
      What is the proper torque for these bolts?
      Should I find stronger bolts? I would still stick to the proper torque, but feel as if these things are butter.
    • By XR-CJ
      Prior to reassembling the case, I tested the shifting and it seems the center fork attached to the shaft seems to stick at the steepest section of the drum. I have cleaned and tested all forks and surfaces for smooth movement, tried it with silicone and oil. With very little help, it seems to shift ok, but without the help, it binds.
      Can I assume that once it is together the oil lines are attached and oil is added to the case, the binding will stop? I have tested every scenario short of assembling the entire motor.
      Should I be able to successfully test the shifting with the case apart?
    • By Charles Mrizek
      contact me if you're interested.
    • By Charles Mrizek
      This replaces the tube that connects the two carbs on a 1987 Honda XR600R (it may fit other years).
      Made in the USA.
      Constructed of TPU  (solvent safe plastic.)
       Its durable stiff abrasion resistant yet flexible enough you never have to worry about breaking it when you're taking apart your carbs.
      Fits the o-ring perfectly and slips into the carb nice and tight.
      Matches the rear shock coil.
      If you would like to buy one contact me via e-mail. They cost $20 Shipping is free (anywhere in the USA). $10 off for active duty or retired military.
      Make your subject: XR600r
