Red Bull Rampage winning run.
That's crazy stuff.  :jawdrop:
Personally, I thought the judging was way off. Cam Zinc finished 2nd, but didn't even make it down his line. I think 5th place Brett Rheeder should have taken the gold then Semenuk then Lacondeguy.
Lachronicly getting his first rampage win! Woop!
The original site was gnarly, this backside of the second site is straight up Scary.
Not do'in that on a DRZ
Awesome video!
Since we are talking about MTB stuff.
Came across this video the other day.
Awesome video!
Rad! Once again Danny is showcasing his mad skills. Cinematography is top notch as usual with his videos.
Awesome video!
I almost couldn't watch some of those riding along the ridge shots.....felt like he was going off any second, but he's obviously toooo good. That was some amazing riding.....unbelievable balance.  :thumbsup: :thumbsup:
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
