Need Tire Advice
Hello, I'm looking for some advice on tires. I'm an all year rider as of this year and am looking for a tire that basically can do it all. I live in Montana where we get a lot of snow so I'd be looking for a tire that I can ride on ice, as well as regular/deep snow. My problem is sometimes the snow melts on the roads/highways and I have to ride on just pavement. Is there a tire I can take both in the mountains to ride on in the snow, but as well as ride safely on pavement, even if it's dry pavement?
I am looking for a studded tire, but if you can't ride safely on studs on the highway when it's potentially dry I'll take whatever non-studded tire that can give me the best results!
Thanks everyone,
Seth :ride:
Haven't used studs in 40 years, but my opinion DOT nobbies like Pirelli MT21's work fine on pavement and some snow. You need studs for ice but won't work well,if at all on pavement.
Maybe someone more up to date will chime in.
Good desert knobbies with Tek screws in them. After a while the tek screws wear their heads off and act like studs. Tubliss and run low sub 5 psi when it snows. When it gets deep carry snow chains
  • Similar Content
    • By Stroupdog
      Not in love with the Bridgestones, has anyone tried something else? Love the Pirelli 32 pros on the KTM350sxf. Also if you have sized up from the 100 90 19 on the back to a 110 or 120? Effect on power? Problem I have now is keepng the rear hooked up when slick and under throttle.  The back will break loose anytime you want, or dont want. I Dont want tire opinions unless you have tried them on an Alta please. West coast moto tracks, mostly NW.
    • By polarbear
      I am looking to buy some new wheels for my crf and have found good deals on DNA Extreme wheel sets. Do any of you have this brand and or know anything about them? I was also thinking of just buying the rim and the spokes and lacing them to my stock hub. If any of you know where I could go to get some good deals I would appreciate it. Also, I don't want to get a crappy set, if there are other brands on wheel sets that are better or anything please let me know what brand and where to buy some. Thankyou.
    • By grayracer513
      This is a question that gets asked often but there's never really been a comprehensive reference for the info. The info here applies to hubs from any YZ model used in a YZ400/426/450. Thanks to Bob Russell at RTR Precision Wheel Lacing for helping collect this.
      Here's how it works out:
      Front Wheels:
      The front hub is the same from 1997 to 2001. Uses 20mm bearings. It can be identified by the four cast reinforcement ribs running across the hub.
      2002 and up use the same hub. This hub also uses 20mm bearings. It is smooth across the center, with no ribs, and has a larger diameter at that point.
      Early Front hubs can be used on 2002 and up by using the 2001 spacers . 2002 hub can be used on earlier bikes by using 2002 and up spacers.
      This information applies to all YZ models from 125-450F.
      Rear Wheels:
      1998 and earlier use the same rear hub, casting number 2VN00 on the hub. Uses 20mm bearings. These will not fit 1999 and later bikes because the axle is too small.
      1999 and up use the same rear hub, casting number 5ET. Use 22mm bearings. Any of these can be used in any '99-'08 model by using the spacers from the year model bike the wheel will be used in. There are four different sets of these, each matching up with a change in the swing arm. You need two for each wheel. They're the same on both sides:
      1999-2001 (5ET-25383-00-00)
      2002 (5NY-25383-00-00)
      2003-2005 (5UN-25383-00-00)
      2006-2008 (5TJ-2530S-80-00)
      Rear wheels from 125's and 250F's have a 1.85" wide rim. All others have a 2.15" wide rims.
      Use the spacers that match the year of the bike the wheel will be fit to, and any '99 or later rear wheel will work on any '99 or later YZF.
      Some have asked about the fact that the drive side bearing and seal on the '06 up hubs are different than the brake side, or than the bearings on earlier hubs. The bearings are the same dimensions as the earlier hubs, however, and have no bearing (pun unintentional) on their interchangeability with other YZ rear wheels.
      Bearing info for '97-up front wheels, and '99-'08 rear wheels:
      Front - 6904-2RS - 20mm ID x 37mm OD x 9mm
      Right Rear - 60/22-2RS - 22mm ID x 44mm OD x 12mm
      Left Rear - 62/22-2RS - 22mm ID x 50mm OD x 14mm
      This information applies to rear wheels from YZ and WR models. YZ fronts will fit WR's, but will not drive the odometer, and YZ spacers must be used.
    • By DeadwateR
      I have seen many threads regarding DNA wheels with many people saying that they are great and many skeptics "hearing" about failures, so I thought that I would add my own personal experience with these wheels. This is a little long, but if you really want to know, you may appreciate the time that it took me to write it.
      I purchased my first off-road bike in March 09, a 2002 YZ250 set up for off-road Hare Scramble racing. This bike had been beat to hell and when I say this, it was justified by the pipe wrapped around both sides of the downtubes, dented frame, chain guide bent with the chain gnawing through the last bolt, ripped seat, and fork tubes that looked like they had been "distressed" with chain links. But the price was right since I didn't have alot of money, but I did have the time and mechanical knowledge to give it alot of TLC. It had DNA wheels on it and and two front spokes were broken. I was told that by the seller that I could probably get spokes easily enough for it.
      So after bringing the bike home, I started looking around the internet for DNA wheel dealers and did not find anything. I did however, find the manufacturers website and contacted them through their e-mail contact, asking for a dealer so I could buy new spokes. A guy at DNA e-mailed me back the same day and said that he could ship me a spoke set and all I had to do was pay for the set and shipping. I was such a noob that I had to ask him if a set meant the spoke and nipple or if a set meant all the spokes needed for a wheel! I think that he realized that I knew so little about wheels that he even offered to re-lace and true the wheel for me with all new spokes if I paid for the spoke set and shipping to and from DNA.
      I jumped at the opportunity since I knew nothing about re-lacing a wheel and I was busy enough tearing the bike down to the frame. So I made a custom box with lots of packing, sent the wheel off, sent him the payment through Paypal and continued to work on the bike. When my wheel came back a couple weeks later, it was in a brand new DNA box, had all the spokes and was trued.
      Upon closer investigation, I noticed that the wheel had new bearings, seals and spacers, but only the broken spokes had been replaced. I figure that he just replaced the spokes necessary and focused the rest of his time and the money that I paid him on the bearings/spacers that needed replaced and to be honest, I was happy and satisfied with that since the customer service was so good to begin with and I now had a complete wheel to put on the bike.
      So, on to my first season of riding. I put alot of hours on this bike, ripping everything from a small motocross track to single track technical stuff, riding through clearcut forest areas where there were no trails with stumps and trees on the ground, ATV trails, rocky brooks, fire roads, etc. Speeds from 10MPH to 83MPH, all with the experience of a newbie which means that I was hitting rocks, dumping it in mudholes, landing short off jumps. I pretty much did everything to this bike except case a jump with it and I am no lightweight at 220lbs.
      How did the wheels fare? I broke one spoke in a swamp when I leaned the bike over while spinning and caught a root from a tree stump with the rear wheel. I broke a spoke on the front wheel and two on the rear wheels when I hit a rock going fast which also flattened my year tire. I later realized that I had not checked the tire pressure before riding and the bike had sat for a couple weeks. I only had 7psi in the front and probably below 12 on the rear.
      End of season one - one broken front spoke and three broken year spokes so I e-mailed DNA once again and got them to send me two sets of spokes so I could replace the front and rear. I sent payment for them and shipping once again through Paypal and the contact at DNA was again very helpful. With much more knowledge about wheels and spokes, I got my wheels ready for season two and I have been pounding them just as hard with very little more riding skill and they are standing up great. My only vice so far, is that I ordered a set of YZ250 bearings and seals last week to replace the rear bearings before they start going bad to find out that you need to buy the bearings from DNA? I just took the wheel off last night and it looks like they are not the same bearings and threads here on TT say that I need to get them from DNA or take them to a bearing shop and get something that matches.
      So, long story short, my verdict on DNA wheels is that with proper care and maintenace (no dumbass newbie tricks), these wheels, spokes, and hubs will stand up to anything that stockers will, and more. They look great doing it, and my experience with their customer service has been excellent! You just need to get the bearings from DNA or find replacements from a bearing shop elsewhere...
      I would definitely buy another set of these wheels. Let me know if anyone has any questions.
    • By alricalric
      Just had a new wheel bearing fitted, but the mechanic said it went in too easily,it's a bit loose.
      So I can feel some play at slow speed when I hit the brake.
      Is there a way to fix the hub, like get it machined for an oversize bearing?
      or welding?
      I just spent a lot on the wheel and dont want to waste it
      Its a kdx200 front, on a klx250
