Help. Suspension spring
I am trying to change the compression springs on my crf 250x.  I can get the shim stack off but after that i cant figure out how to get the spring out. Hope someone can help.  Thanks.
You have to unscrew the tap off the rod , you can hold it in a soft jaw or make a tool to unscrew it , or unscrew it via the nut within the spring (using a sensible amount if heat to help break the thread lock
Thanks for the quick reply. I will give it a shot..
