fcr pilot jet 42 or 45
think i might already know the answer but would like to run this past thumpertalk guys. i've recently changed my pilot jet from a 45 to a 42. when i am at the base of the mountain i ride up i have the fuel screw set at 2.75 turns but it won't stall until 4 turns out. when i am at the top of the mountain it will start to stall when the fuel screw is adjusted to 3.5 turns out. it idles well but has a small hesitation from idle to about 1/8 throttle.when i adjust the pilot circuit how many turns out should it be before the bike stalls. should i put some tape over the airbox to confirm it is a lean setting? i can't compare it to the 45 as when the 45 pilot jet was in i had a worn needle and seat, i have since replaced it
Fuel screw is something you adjust once and do not touch or mess with again,  they say if you need to be more then 3 turns out,  you need a bigger pilot jet.
When you get to the top of the mountain and it stalls at 3.5 turns out compared to 4 at the the bottom of the mountain is normal. I would read the "confirming your pilot circuit in the FAQ's. Fuel screw setting will always change with altitude,temp,humidity and engine temp
If the bike runs with the fuel screw closed, the pilot is too big.
If you have to have the fuel screw open more than 2.5 turns, the pilot is too small.
45 is the normal pilot. I imagine a 42 might be needed on a hot day at 8,000'
it is all about air density (temp/relative air pressure and humidity)
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
