Just stole a bike!
Picked this bad boy up for a whopping 375 bucks!!!
Owner was about 60 and said it just wouldn't start one day, brought it home and started first kick! Kinda feel bad for the guy but if I didn't buy it someone else woulda
Ktm 520sm
That's awesome!
Pretty sure it needs a right side crank seal, bike has no power and was dropping oil after only like 4 min of running ImageUploadedByThumper Talk1412540285.641797.jpg
Ktm 520sm
But the good is it has v force reeds that are in great shape, full pro circut exhaust(chamber is pretty dented up)
And I nice soft aftermarket seat!
Ktm 520sm
even if you spend 500-800 on her you got a smoking deal
What a steal!! Nice find
Seems to have good compression, piston look to be in good shape through exhaust port.
Needs crank seals
Chain and sprockets
Rear wheel bearings
Even came with a new rear tire!!
Ktm 520sm
Will do a compression test tomorrow
Ktm 520sm
My 01 from brand new had the right crank seal leak on me from day one.
I have one of these turds but paid $1200 for it, nice score! That back tire also looks super fresh. Once you ditch the 36mm TMX and let the motor breathe it graduates from a turd to a really great bike. The top end keeps pulling and pulling. I also bought mine with a bad right crank seal, but after the bearing seized I rebuilt the whole motor. A few rides ago it started spooging again, but I'm long overdue to repack my silencer. They are really fun and light bikes, easy to throw around. Oh yeah, send that pipe to pacific pipe repair and it'll look like brand new for $60.
Edited by dan2581
Well I replaced the crank seal and no more sploog! But the power on this thing just seems so flat, something must not be right. It screems but it doesn't pull like I remember my yz125 did...maybe I'm just used to the power if my ktm 520? I don't know.
Power valve is working, maybe it's not opening all the way???!? I don't have a manual but from what I understand you install the actuator arm so that when the motor is off the powervalve is sitting up against he stop pin
Ktm 520sm
Compression was at 150psi as well so top end is still in decent shape
Ktm 520sm
Stock mikuni is jetted way too rich stock the Keihin pwk swap really helps though. The stock needle on the mikuni is the problem you have to go like two needle sizes leaner it's a must.
Well jetting is right on with pro circut specs, and I'm basally at sea level. I mean this thing is flat on power, no pull what so ever compared to my 01 yz. It was Idling pretty high when I got it I'm thinking an air leak but not sure, had to turn my idle screw out At least 3 turns to get it to idle at the right speed. I'm thinking left side crank deal
Ktm 520sm
Glad to see progress! Have u seen the DIY leak down tester somewhere here in this forum? I think that might help u narrow it down. In fact, if u want il ship u the one i made. Hit me up if u want it.
Edit - no charge, just goodfaith u would send it back
Edited by RBI
Not saying it won't run on stock jetting but it's boggy and flat. I went to the specs listed by dirt bike they got from honda it made the bike a lot better.
I mean the wheel won't even come off the ground in first gear, no bogging anywhere. Jetting isn't stock but not too far off, it's pro circut specs. I think my problem goes further than jetting
Ktm 520sm
Ktm 520sm
What did you end up getting on your compression test?
150psi, enough where the bike should still run good, starts right up but the power just isn't there
Ktm 520sm
Ktm 520sm
What do the reeds look like?
They looked good, there v force 3.
Although it's been a while sense I had a 2 stroke and didn't hold it up to a light to see of they were fully sealing, I think they are good but I will double check that tonight after work
Ktm 520sm
