Boyesen reed wear?
I just bought a '97 CR500.
I'm going through everything to make sure it is in good shape.
I just pulled the reed cage and need some advise on what I am looking at.
The base piece of the reed set has troughs in it in three places.
Almost like a path was burning through between the reed cage and the reed base piece.
Can someone tell me what I am looking at here? In the attached, pic, the arrows point to what I am taling about.
Also, I need to figure out which reeds to purchase to replace these.
Thanks,
Robert
Edited by rcpaisley
Yes, call boyesen!! I did last week and received awesome help!! They made two different rad valves for the 500. There is a number stamped on the side of the housing. Give them that number and they will set you up. About 45-65 bucks. I'd recommend going with the pro carbon reeds, well worth the extra $20
Yes, thanks!
I will call Boyesen tomorrow.
Apparently it is a Rad valve that I have.
I am used to tearing apart 4 stroke motors.
I am definitely on the learning curve with the two stroke parts.
I am looking forward to running the 500 in vintage races as well as the desert.
Robert
