Throttle Cable Repositioning
Hey guys, i currently have an issue where my throttle is sticking when i lock it to the right. ive tried pretty much everything but i still cant seem to either A) route the cables correctly or B) figure out why it is sticking. My best guess is i'm not routing the cables correctly. So im wondering if someone has any pictures of there entire throttle assembly and where it routes. Some mods that may effect my Routing are the Trail tech X2 headlight and also silicone radiator hoses.
Thanks for any and all replies :)
When your bars are straight does the throttle snap back to closed when released? And are your cables clean? You might have a fray.
I have my throttle cable routed kind of funny to be able to swap jets easier. Even with 2 more bends than stock positioning mine still snaps closed with force.
Edited by JSY
yes it does
Premature post. Edited. ^^^ haha
Hmm, mine just refuses to close the throttle when locked to the right, locked to the left has no issues
And yes, the cables are clean, and no freying on either ends
Edited by mdavidg
Certain circumstances can actually cause frays within the cable. Try disconnecting both ends and see if it makes scratchy noises as you move it back and forth through the shroud.
If you have a BSR36, mine goes like this.  First it goes through the guide.  Then it goes around (in front of) the cluster of wires etc.  Then it crosses through the frame (in front of the coil).  Then goes strait to the carb.
Edited by Throttle5
Check to see if you have any free play in the throttle when turned right. Sometimes adding a little extra play in the cables will fix your problem. Also you can run the cables on the right side of the frame and  help the situation.
I agree with James509.  Did you had risers/height to your bars?  I did so, and because of this, had to re-route the cable down the right side of frame.  If its when you turn the bars to the right, then it sounds like your cable needs more slack.
Personally i didn't figure what the problem is, but my local garage has sorted it for me since i got him to check over the entire bike as i just rebuilt the entire thing and was abit scared of riding it without a quick once over by someone who knows what they are doing :)
So thanks for all the replies anyways
I had the same problem when i adjusted all the slack out of the throttle cable. I had to adjust a little slack back in at the carb. To get it to stop.
