PW 50 and PW 80 stock carb settings?
I have both sizes of little PW, one for son other for daughter, and am trying to get them running right. Both usable now, but with little issues. Both completely stock, exhaust, intake, everything. Both bought used, so I have no original paperwork. I've tried googling and searching my ass off, but can't find little things like the correct bowl float height. Stock jetting to confirm if prior owners messed with it or not, etc.
PW50 runs fine, for a starter 50cc. When sitting in the garage on the center stand though, it slowly drips a huge puddle of fuel. Bad float height? Maybe.
PW80 doesn't run as smooth, and is a royal pain to start cold. While running or stopped fuel slowly drips underneath if pet ock is on. Bad seals, or bad float height. Doesn't look like a leaky gasket, so I wanna check float height, and the rough running makes me think the idiot PO &%$#@!ed with it not having a clue. Wouldn't be the only idiot surprise this bike had...
So, any one know float height or jetting for a ~2012 PW50 or a ~2005 PW80?
  • Similar Content
    • By Rick Mcqueen Art
      A tiny clear rubber tube on bottom of carb.  On bottom sort of on side, by floats, the other end just hanging down.  Was it always like this? Or does the other end go somewhere?  Today after multiple trys with kick, choke on/off ,,,fuel keeps pouring out the tube.  This bike has always been hard to start.   Thanx  guys!
    • By Brock granberg
      I just did my valve adjustments and put my YZ250f back together as far as the valves, shims buckets and cam covers on but I need adhesive for the plastic valve/cam cover and I am stumped as far as what to use and where to get it or even what to call it! Need to get some soon im in need of a ride!
    • By ThatE30GUY
      Hey guys, I bought this YZ85 and came to realise the clutch wasnt working, so I drained the oil (Jet black) and pulled the plates out and cleaned them. I assumed finding a torque wrench would be easier than it has been. Does anyone know how to torque the clutch springs to spec without a wrench? Any insight helps.
