ssr 125 rear axle torque specs?
I changed my rear tire to a mx 52 on my ssr 125. Putting it back on the bike. The manual calls for 35 ft lb. So I torque it down to 35. Its so tight that I can barely turn the wheel by hand. Loosen it to 30 lbs same thing then 25 and then 20.... Even at 20 ft lb it doesnt spin freely.
What gives?
You have the spacers in wrong then. Something must be rubbing the bearing. Did you keep the 2 spacers or loose one or both?
i have them both in...
