DRZ400e Shock rebuild suggestions
So the 5.7 spring came in from factory connection, looks as good as a spring can lol. The bike sagged a lot in the rear so I wanted to go with a stiffer spring for my weight. The question I am left with now is whether I should just have the nitrogen checked and recharged if its needs it and throw it all back in the bike or if I should have the shock rebuilt at a shop, time hasn't been my friend lately so I am not sure if I would be able to spend the required time rebuilding it myself.
Anyone have any idea what a shop would charge me if I took my shock to them for a rebuild? Just wondering if it would really be worth it.
Providing there is no issues with the shock, it's only a service, clean and flush, new oil and gas recharge.
A revalve on the other hand would cost extra as it is more labor intensive.
Sometimes the bump stop rubber needs replacement and depending on how old the shock is, I would get a new seal fitted while it's apart.
Any shock that has seen as many hours or miles as yours likely has (2002 E?) will benefit from a service.
Expect to need a new bottom out bumper, oil seal, bands, shaft bushing and oil at a minimum. As long as the shaft is not damaged, and the rebound/compression adjusters are not damaged it "should" be a straightforward service.
