Idle/start up problem
So my problem is after I crashed my dirt bike and broke my triple clamps, which is now fixed, the bike now starts and revs way high. Like scary high. So high that I shut my bike off for fear it will break high. Idk if when I fell it did something to cause it. Or maby I need to adjust the carb. I'm not sure. I am attaching pics as well. Any ideas would be great! ImageUploadedByThumper Talk1412784893.138549.jpgImageUploadedByThumper Talk1412784911.521189.jpg
Verify that the throttle cable is seated fully into slide.
also your throttle cable should be behind the petcock.
and your carb boot( part that bolts to motor ) looks pretty cracked up, any air holes will rev the bike.
Yeah that's why included the picture of the carb boot. I think it's something to do with the throttle cable. Just haven't had time to mess with it. I'll report back with anything I find. Thanks for the replies
remove the cable from both the carb and grip and make sure it slides completely and easily both ways.
Yeah I'm just getting ready to see if adjusting it helped at all. I hope it did
So I adjusted my airscrew and that lowered the idle to a respectable level
Check where the throttle cable goes into the throttle tube housing. The bottom half of the threaded part is plastic. Probably broke when you crashed. Has this happen on my sons bike. You play around with the cable and it slips back into place. Check it, if it is broken you are just asking for a stuck throttle.
Ok I'll check it out. I think it was ok though cause I think I checked it when I undid the throttle housing and it looked good.
  • Similar Content
    • By Zach121
      Alright, found three bikes all located where i live in Texas. I know they're all very different, but if you could tell me what you think each bike is worth, and which one would be the best deal. Thanks.
      Notes: Both 2 strokes have new top ends. I think the front brake lever is broken on the kawasaki.
      KX250 2002 $800-$1000?
      YZ125 2000 $1250
      KTM 400SX 2002 $1200
    • By Ryan Turner
      So I'm at a bit of a cross roads, I currently own a 06 rm250 and I love it. I also have a 02 kx250 which I'm selling with intent to buy a newer two stroke. I can't afford a newer ktm and the older ones aren't that great and kawasaki never impressed me. so I'm stuck between 06 yz250 and 05 cr250. I've heard the yz and rm after 06 are almost the same bike just the Suzuki handles better and the Yamaha has better suspension. So I'm not sure if I wanna buy carbon copy of my bike with slight differences. That's why I'm interested in a cr250 I heard the 02+ models RC valves are shit garbage but was mostly fixed in the 05-07 models. I ride at a track and at some bogs down the road from me. So from people who have owned both, what would you recommend. I know the cr is known for a hard hitting power band which I enjoy since im an aggressive rider. Should i just see which deal comes my way first.
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
    • By 02YZ426
      I thought it would be interesting to see what everyone in this forum is riding... So post them up
      Here's my 2006
      And my buddies 1996 KX250 that I just finished fixing up. Motor completely rebuilt and ready for the track.
