XR80 runs bad - help
My son has a 2002 XR80R.  It is good condition and appears to have low hours; he has been riding it for two seasons.  It has started to run poorly and I can’t seem to pinpoint what the issue is, if you have any advice please let me know.
  • A few months ago the bike started to idle poorly; it would idle fine then drop 150 – 200 rpm.  I compensated by increasing the idle.  The problem with this is that it idles too high, except for when it drops down.  It will drop down every 60 seconds or so and it will stay low for about 15 seconds then climb back up.  It does not do it when it is cold, only when it is warming up or hot.
  • I just assumed that it needed a carb cleaning, so I took it apart and cleaned it thoroughly.  I put it back together and there was no difference.
  • The bike runs fine otherwise; it revs fine and seems to have no loss in power.  With this in mind I assumed it might be a bad pilot jet, so I bought a new one (same size - which is the same as factory setting).
  • I put the new pilot jet in and there was no difference.
  • Then it started blowing white smoke, it would do it on start-up and during idle, even when it warmed up, but mostly at low RPM.  Right around this time I had just switched to No-Toil, I just assumed that I probably put too much on the air cleaner as I can’t seem to see any oil loss on the dip stick.
  • The current set up is:  Air mixture screw – screwed all the way in.  Idle screw – also screwed all the way in.  It seems a little insane to me that the idle screw would have to all the way in to run.
  • There is only one other piece of info that I should add:  When I cleaned the carb I noticed that the idle circuit seemed to be plugged (I could be wrong, let me explain).  There are two small tubes on the filter side of the carb.  One of the tubes goes to the air mixture screw, then to the pilot jet.  There is a small hole on the engine side of the carb that I feel should be connected to this idle circuit but no matter how much carb cleaner or compressed air I force into it, it just keeps coming back out.  It looks like it should connect to the pilot jet, but nothing goes through.  I have tried pushing safety wire through and it just stops.  Should it be connected?
Your thoughts?  Thanks
Each and every little hole comes out somewhere. Mixture screw should be at 2.5 turns out. Be sure it has a washer, spring and O ring on it.
Idle screw should only be in far enough that it just starts to lift the slide. Look in from the air filter side and see if the slide is all the way down.
Sounds like its running too lean on fuel. Make sure the mixture screw is 2.5 turns out. If that fails, you can go on amazon and get a brand new carburator for 25$
Yes, I was thinking the same (buying a replacement carburetor), are they really only $25?
any idea where the white smoke is coming from?
4strokeridertt, according to this schematic on Bikebandit there is only a spring for the air mixture screw.  Mine does not have a washer and o ring.
With the sporadic idle it sounds like there might be an air leak, which would also make it hard to fine-tune the carburetor. To test for this, spray carb cleaner around the intake with the bike running. If the idle changes there is an air leak.
The white smoke could be a sign of worn rings.
Edited by GrimReaper_503
ok, I will give this a try
I bought a Chinese carburetor from Amazon; it was $19!  I installed and it runs much better.  There is a bog in the mid range but I think if I raise the needle I should be fine.  The white smoke seems to be almost gone (maybe my imagination).
i am still baffled as to why the little hole on the engine side of the carb is blocked, I am convinced that this why the other carb ran so poorly.  Has anyone ever heard of this?  I tried cleaning it with carb cleaner, compressed air, soaking it for a few hours, I even tried steel wire, the obstruction won't budge.
Thanks for the advice
  • Similar Content
    • By spezza-125
      Anyways so I got a 1985 xr200r RFVC, and I have heard that the oil really overheats and in some cases people have had their bike (Rarely) go up in flames, however I don't want to take any chances and I heard that there is a way to put on some sort of oil cooler... How do I do it??
    • By Yamiha
      I have a '01 XR200 and i was wondering it anyone could give me a top speed for it. Where i live its more 2 lane highways and things so i cant find a good straight to run it with a car in. Thanks
    • By Quick Draw
      I decided to compile a list of common modifications for the XR200 in hopes of eliminating some of the common questions asked on this forum. These modifications are intended to improve the overall performance of the bike, without sacrificing reliability. Feel free to suggest amendments or things to edit.
      The XR200 is an excellent offroad machine; however, it was for the most part obsolete about 20 years ago. The bike can still be accredited to having probably the best reliability of any full size bike out there. When properly setup and modified, the "little XR" can run with the modern big bikes, especially in the tight and nasty technical terrain.
      INTAKE: Remove the airbox snorkel on top of the airbox. It just takes a little prying and it's out. For $20-$40, you can get an aftermarket filter (UNI, TwinAir, No Toil), that will help increase airflow. Rejet one size up on the main and pilot.
      Here are the stock jetting specs to give you a basline:
      Stock jetting
      XR200 (not XR200R)
      main 102
      pilot 35
      Needle position 3rd groove
      Pilot screw initial setting 1 3/4 turns out
      XR200R (81-83 only)
      Main 138
      Pilot none
      Needle position 3rd grove
      Pilot screw initial setting 2 1/2 turns out
      XR200R (86 and later)
      Main 112 (86) 110 (87 and later)
      pilot 38 35(98 and later CA only)
      Pilot screw initial setting 1 1/8 turns out
      When these things are done, the bike will breath much better. This is the single greatest modification for a bike ridden at high altitude.
      Overall cost w/out filter: about $10 for jets; $20-$40 for the aftermarket filter
      ENGINE: The greatest improvement to the XR200R engine is a big bore kit. Here are the 2 most common kits: http://www.powroll.com/P_HONDA_XR200.htm
      Other options include porting and polishing the head, high compression pistons, hotter cams, etc. The more you do, the more reliability is reduced, but it is a trade off for power. Another option is an ’83 -’85 ATC200X cylinder head. It has a .5mm smaller bore, so it would need to be bored to 65.5mm, however, it has much larger cooling fins. For motors that are constantly being run in extreme temperatures, this is an option to consider.
      Overall cost: Varies by modification, expect to drop $200-$1000
      EXHAUST: There are several aftermarket exhausts on the market. These range from silencers to full systems. Prices range from $80-$500. Most aftermarket exhausts will give about the same improvement. The engine will rev quicker, which can be nice, but mostly they all just make the bike louder. For mild improvement to the stock system: grind the weld off of the inside of the header and remove the small cap held on by 2 8mm bolts at the exhaust tip.
      Overall cost: 0-$500
      SUSPENSION: This is a major weakness with '92-'02 XR200s. The first option for the forks is to give the springs more preload by adding a larger spacer on top of the springs. The second, most common option is to swap out the entire suspension. '84-'91 XR200 forks and rear shocks will bolt right up, and ‘81-’83 XR200R forks will with the corresponding triple clamps. '84-'89 CR125/250 front ends will bolt up to any XR200R with the addition of a spacer. This particular swap is more complicated, but also adds a disc brake and improves the bike tremendously when used in combination with an '84-'91 XR200 rear shock. See this thread for more info on CR front ends: http://www.thumpertalk.com/forum/sho...1&parentpage=2 These parts frequently show up on Ebay and can be obtained very cheap. Also, a visit to racetech.com or similar suspension tuning company couldn't hurt with any setup. Emulators and progressive springs will get conventional forks nice and plush. Currently, XR250 rear shocks are in question as to what years will work; therefore, I do not recommend them at this point. Many people have them on their 200, however there is not a definitive answer for the years yet. Be sure to research before you buy.
      Overall cost: Generally less than $100; for Racetech tuning, expect to drop $200+.
      WHEELS: An 18" rear wheel from an '86-'89 XR250 will bolt right up. This can help because the 17" wheel spins too much sometimes, and tends to work its own spokes loose. There is also a much greater tire selection with the 18" rear wheel.
      LIGHTING/DUAL SPORT: Lights can easily be added to the 200 by tying into a pink wire that just comes up under the tank, then loops right back down to the stator. This wire has no purpose, and was left behind in the wiring harness, because the non-American XR200s had lights, and Honda didn't pay to change the wiring harness or the stator. I have personally tested it up to 75 watts, but I wouldn't recommend going much higher. From there it is simply a matter of wiring it the way you want it. In any application you will need a 12v voltage regulator. I would be happy to assist with any questions on the wiring you may have, since I have redone mine several times to change things. Also, please visit this thread for some diagrams (about halfway down the page): http://www.thumpertalk.com/forum/sho...d.php?t=431097 Each wiring job is different, so it is difficult to write a generalized way to do it. For dual sporting, there are kits from Baja Designs and similar companies, or you can be creative and pull parts together yourself, and in result save lots of money. The first time I had lights on my bike, it only cost me $6. A speedometer cable can be attached to the speedometer port on the front brake hub, as long as you can find a way to mount the speedometer. TrailTech computers are the easy alternative to the manual speedometer.
      Overall cost: Dependent upon creativity. Baja Designs kit runs around $450
      Helpful XR200 Links:
      www-staff.lboro.ac.uk/~elvpc/papers/XR200.html (engine info)
      http://www.4strokes.com/tech/honda/lightup/ (adding lights)
      **I need more links for XR200 INFORMATION, NOT PRODUCT websites....Post them in this thread if you have them***
      Again, please feel free to suggest editing....I'm sure there are MANY things I forgot. This is just a baseline to get started.
    • By Footy
      I don't have photo access yet but lets see your 200's.
      My dad is planing on selling his 02 XR 200, but it's in need of a rear shock. I was told that these shocks arn't servicable, so we priced a new one out. The dealers asking over $400 for a new one. So my question is, what other bikes have a rear shock that will work on his 200? Thanks.
