well finally completed the conversion to a ful rmz front end......
was it worth it
hell yes
ok, now tell us how you did it.
Ooohhh, i would indeed also like to know how you did it :) would love an alternative to using just rm forks..... seems to be many rmz forks out there for a relatively decent price
What did you change?
List of parts/ a DIY write up would be epic. I'd love to convert to better front forks in the future.
Without pics it didnt happen... ;)
hi guys,
have some pictures,
am busy at work in the week so will try post more info at weekend
everyting on my conversion is RMZ,so basically started from a headstock with no bearings(best way when you know what i know lol)
picking the right RMZ parts is important to get the offset right
i also have a scotts damper fitted with an BRP (american) underbar setup
and yes i will never get my money back,but i love the old girl and she still does well at the odd rally
We definitely need a detailed write up.  Sounds like you did a pretty nice conversion.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
