CanAm 2008 Can-Am Renegade 500 / A few problems
I just bought a Used 2008 Renegade 500. Clean quad. 11000kms
Couple of problems I have found after getting it home. Bear in mind this is my first quad. A usualy ride motorcycles.
1/ Both front brake levers Very stiff , only move in 1/2 inch....guess need bleeding ?
2/ Transmisssion oil leak from front diff around main shaft seal.....big job ??
3/ 4x4/4x2 light on dash stays on (although I dont know if it is supposed to be lit up by a bulb) the lcd in black stays on regardless of switch possition...I can here a servo when switch is latched either way.
4/ The Dash sates "service soon" , when I have a reciept that a service has just been done. Plus it gives the welcome message in last owners name. Can I reset this myself ?
5/ Where are the front light fuses ?.... They were working until I switched the key from ON to ON with the light bulb sign, now they wont work. Yes, I know they should work in the middle poss only, but in this case not.
Any help would be much appriciated thanks
