KTM 125 with KTM 250 SXF suspension
I am purchasing a KTM 125 2014 this weekend. The owner has removed the rear shock, forks and springs and replaced them with the same stock parts from a 2014 KTM 250SXF. I think these are the same except the spring is  rated at 80kg?? I am 90kg so would I need to go up to a higher rate spring? or will the standard KTM 250 SXF setup be suitable?
