KX100 pipe O ring size?
  • 4 weeks later...
I finally got to measure the pipe and order O rings. It takes 33mm X 3mm ones, which I discovered the PO used american size ones and that caused great difficulty getting the pipe back in place. With the correct metric ones it works slick. Kawasaki gets $6 each for these, and the O Ring Store gets 47 cents each, so I got 10 of them for less than one from the dealer.
Depends on what material you get. I got plain 70 durometer Buna-N since it holds up to fuel and heat (to a point). They have dozens of different materials available. Anybody know what the OEM ones are made of? They look like normal ones.
