DRZ-125 missing and backfiring
Working on a 2005 drz125 that has sat for about 5 years.  Wouldn't run when I got it, so I started with the usuals.  Cleaned carb, checked compression, changed oil, spark plug and set fuel mixture screw to two turns out.  Bike runs great until it gets hot.  I starts to stutter from mid range rpm's to high. Also backfires simultaneously, almost like its about out of gas. Drained new gas and replaced petcock, cleaned carb again only to have same results. I'm thinking it's something electrical but not sure what the resistance should be on the pick up coil, pick up sensor.   Any help would be appreciated. I'm at a loss at this point.
I agree it sounds electrical. Message me with an email address and I'll send u a weather report with will give you the information you need for the resistencia.
I agree something electrical is failing when it gets warm/hot and it's losing spark. I'm guessing coil, but that us just a guess
Edited by eprovenzano
