2006 crf250r piston
Replacing the piston on my 06 crf250r. Should I go with a OEM or aftermarket one? And if I go to a higher compression ratio then factory does anything else need to be changed?
I've ran 13.5:1 on pump without a problem
I'm not sure as far as oem vs aftermarket though I'm under the impression JE and Wiseco>OEM
You wont have an issue with a 13.5 as long as you use good 93 octane. If you are sticking with stock compression I would stick with oem, higher than that I would go JE. Though, I have used wiseco pistons with no problems in the past, and I havent heard any stories about them either.
