4 stroke 125 orione pit bike help
Iv got a 4 stroke 125 orione pit bike and I went threw a bit of water, came out on the other side of the puddle and it was running sounded a bit different but once I opened the throttle it seemed fine, then I took a lap around my chain came off so I shut it down put the chain back on and it wouldn't start. Once I got home I kicked and kicked and kicked it finally started but it takes a while to get it to run, won't idle anymore atall, and when I get it running I shoot flames out of the exhaustImageUploadedByThumper Talk1414355512.621007.jpg
  • 1 month later...
Ok I changed oil ran a full bottle almost through before I filled it again, changed my spark still nothing, so pretty much screwed huh lol
Do you actually have a spark? Pull the plug and put it in the cap then hold it against the motor and kick it over. If you see a spark, clean your carb and try to start again. If no spark you likely have a bad cdi or stator or at least some loose wiring.
