Why a 2-stroke?
Seems like an obvious question and probably will be to most of you. I don't want to open a negative approach to 4's, but just to understand why you ride a 2-stroke.
Positives
  • Braaaap factor, because they kiss ass
  • Easier to maintain/service, easier to work on
  • More cost effective/cheaper to maintain
  • On demand power
  • Lighter/Maneuverability (less rotating mass)
  • Smell of pre-mix
And the negatives
  • Have to pre-mix
  • Burns fuel faster
  • Engine braking
  • Less torque (comparitive)
  • You will have to do most the work on your bike (since you'll feel like a retard if you don't)
What are your experiences..?
Edited to add the great feedback
Edited by TukTuk
Until 2013 I'd ridden my XR400 for 13 years. Great bike, but just getting too heavy to continue to throw around on the kind of trails I still want to enjoy. I'm 57 and thought a lighter 2 stroke would allow me that, so bought a new KTM300. Rode it for a year then put a Rekluse in it. Its a fantastic old man bike. I can ride it lazily or wick it up.
I've never owned a stroker because of my upbringing, and the expense.  Also I love technical riding, and the 4t heats up too much riding super slow terrain.
Plus 2 strokes handle better, though the 4t counterparts are becoming better and better.  You almost don't feel the extra weight on a four stroke until you have to pick the bike off the ground (according to a new four stroke convert friend of mine).
Pros:
Easier to work on
Cheaper to work on
Lighter
Pre Mix smells good
Handling (for the most part.....depends who you talk to)
Better smiles : miles ratio  👍
Cons:
I guess you gotta mix gas  :excuseme:
Handling (depends who you talk to)
Positives
  • More cost effective to maintain
  • On demand power
And the negatives
  • Have to pre-mix
  • Burns fuel faster
because they kick ass
Let's compare my 2 bikes… KTM 144SX and 250SXF
144SX:
- Ultralight weight (197lb dry)
- Easy to maintain/service
- Shorter intervals between service (50 - 60hrs max vs 100hrs on 250SXF)
- Immediate power delivery
- 1 power pulse per cycle = less grippy rear traction
- Less reciprocating mass = more twitchy to ride
- No engine breaking = entering corners faster is much easier
- Cheaper to purchase new or used
- Cheaper parts all the way around
- More technical data available for tuning/easier to tune
EFI 250SXF:
- Heavier (232lb dry)
- Extremely difficult to maintain for the average person
- Longer service intervals (100hrs vs 50 - 60 on the 144SX)
- Slower power delivery
- 1 power pulse per 2 cycles = more grippy rear traction
- More reciprocating mass = more stable to ride
- Substantial engine breaking = much more difficult to maintain speed entering corners
- More expensive to buy new or used
- More expensive parts all the way around
- Less technical data available for tuning/very difficult to almost impossible to tune properly without specialized tools
Really truthfully, there are many pro's to modern EFI 4 strokes:
- Better rear grip
- More weight over the front end = better front traction
- Better, more accurate fueling and substantially smoother power delivery
Positives
  • Braaaap factor, because they kiss ass (they kiss ass?)
  • Easier to maintain/service, easier to work on (definitely)
  • More cost effective/cheaper to maintain (definitely)
  • On demand power (Wouldnt 4 strokes be considered more on demand power?)
  • Lighter/Maneuverability (less rotating mass) (Sure)
  • Smell of pre-mix (If youre into breathing dead organisms [lol])
And the negatives
  • Have to pre-mix (Takes 2 minutes)
  • Burns fuel faster (Bigger tank)
  • Engine braking (Can be a good or bad thing)
I'm suffering the same dilemma. I like the 4 stroke power delivery and stability. I had a few 125s when I was younger. Although I haven't had any serious problems with my 250f, I feel like it's only a matter of time until these electronics fail. So I would like the simplicity of a 2 stroke and the cost savings. However, I would change oil just as often in either bike, if I do one piston a year in my 4 stroke and two in a 2 stroke, am I really saving money? I own a ktm haven't had to do valves yet. Plus I've never been really good at tuning carbs and I know nothing about the power valve. I come to this forum once in awhile to see what kind of problems exist with the 250sx's and how to fix or tune them.
I want a "Do All" bike because I mostly ride moto but I like trail riding and hare scrambles also. The 250sx and 350sxf are my choices. If I could find a good deal on say a 2012 250sx that needs a rebuild I'd snatch it up for the learning experience and to test the waters. But I can't really afford to sink 3k into a bike I might not like.
For me 2t are less finicky. Compression, air, fuel, and spark. 4 stroke. valves, compression, air, fuel, spark, accelerator pump. Efi eliminates some of that. Leak down tests. I'm sure there are some other pros and cons but 2 strokes just have fewer things to worry about/adjust.
Torque wise, I think they have plenty and then some more. I can go anywhere and even faster on a 2stroke that a four stroke.
One of the things I look for on bikes are weight. The less weight you have the better (to a extent) since they are so flickable. There were a few times that I lost it but corrected my self on a 2t. I would not be able to correct it on a 4t because of the weight and momentum
