2003 Honda Crf450r impellor removal.
Hello, I want to remove the water pump impellor on my crf450. I removed the cover today and tried turning on the bolt inside but it simply turned the motor over and would not come loose. What do I need to do to get this impellor loose? Thanks.
have someone hold the rear brake, and have it in gear.
Be sure you are going "lefty-losey" (as noted above if you use an impact) .. a good hard turn with the wratchet usually does it. Just a nice easy turn, building pressure, doesn't often get it lose.
