Moving FMF tail pipe
How about a steel or aluminum spacer of the needed length to not make it rub? Sounds pretty simple to fix really. My FMF PC4, although newer than yours, does not rub with a 150 Pilot Power tire.
The post above mine may be playing a part as well. If your suspension is moving that much that often, your rear shock may need some attention. Either more preload or a stiffer spring.
Edited by Jasonb85
Should I adjust it higher now that I am primarily doing SM?  Does anyone know what my SAG should be?
I have a 6.0 spring on it.... So I don't think thats the problem....
