Problem Starting my XR650L
As stated in the Title I have a problem starting my XR650L. When I press start and leave it pressed it won't start. If I press start then let go and then press start again and let go.. after a few tries it does start. Any help will be greatly appreciated.
Sorry if you have a hard time understanding me, English isn't my first language.
Assuming there are no other symptoms (lights not turning on, headlight not dimming when starter button is pressed, clicking sound from starter or battery box) it sounds like you have a bad connection in the starter button on the handlebar. Take it apart, inspect, repair/clean.
Agree that the switch may be the culprit. Either that or the starter solenoid.
