Won't shift into first
Just did a bottom end on my 06 rm250. I ran it through the gears before I put the clutch in and it worked fine. I slapped it all back on the bike, started it up in neutral and it won't shift good. Besides not getting it to go into 1st when I upshifted it slammed into gear. I'm hoping the cases don't need to be split and I can fix this by maybe realigning the star. Who knows maybe it slipped off and aligned itself not facing each other perfect. Any experience with this?
split the cases again. Pay attention to a parts diagram, as you inspect for the error. You may have put a gear on backwards, or a thrust washer in the wrong spot. Trans shifts fine while the cases are split, but binds up when they're together (been there, done that). After you re-assemble the cases, always check the shifting.
