Only runs on res
Like it says my 2003 rincon only seems to wants to run on res? Anyone elase havin this problem will it run like that all day? Have a group ride happen on the weekend and need to be able to go hate to go and it only run a few miles tried to tonight rode around a bit as soon as turned the fuel to on sputtered and died?
Drain your fuel tank. Clean out the inside of the tank, put some fresh fuel into it, shake it and pout/filter into a clean coffee filter. Repeat until no debris is in the coffee filter.
Remove the petcock. Take it apart and clean it.
Reinstall the petcock
Refill the tank with fresh, clean fuel
You probably ought to remove the carb float bowl too and ensure it is clean inside.
