Which antifreeze in CR500
If you run a ethylene glycol based auto coolant, use the "extended life" version. It does not contain silicates, which shorten the life of the water pump seals.
What he said, is what you should use. It is a lighter green color than your used to, but not an issue for motorcycles without reserve tanks. With reserve tanks it's a little harder to see the level because it's not such a dark green. you can also use this http://www.evanscooling.com/  <-------
Edited by Atieri
