2015 xc-f staling
make sure your idle is at least 2100 RPM, you may also need to have the TPS checked to make sure it's in the correct position. I'm sure if you do some search here you'll find plenty of posts on that subject and if not here you will on KTMTalk.com..
I also found that a FWW does help a lot, but the best mod so far is the Rekluse on my bike!!!!
Thanks lads, iam in the uk so not really a lot of xc-f's about, the bikes only 10hrs on it so may give it a few more hrs an see if it beds in, I had the 350 exc before I traded it in for the xc-f loved it but the xc-f is a lot more fun an once I get the stalling sorted ile be over the moon with it,
