Play bike build
I was thinking sometime when I get the money id like to build a play bike. I was thinking if buying a blown up rm or kx 100 or an 85 big wheel and putting something like an xr 100 engine in to to make it low maintenance and reliable what are your thoughts on this
Klx 110s I have found to be the most fun play bikes, compact, fast enough to be fun, and a lot of aftermarket
so would putting a klx110 engine in a kx or rm 100 frame be worth it I was also thinking a ttr 125 engine to put in one because I can find lots of trashed ttr125s for sale where the engine just needs a little work. The klx 110 dont usually come cheap around here.
I was thinking just a klx110 itself, if you're going to do trail bike in mx frame do I suggest a 150f
Plenty of aftermarket, easy to find, enough power
