Need a machinist recommendation
I have a late 60's Honda CT90 that I've been working on and it needs a crank rebuild. The rod and its bearing are shot (as most are). In order to change them you have to split the crank in half which is a much bigger job than what I can do in my garage. Well I guess I could probably get it separated, but definitely couldn't get it back together without a ridiculous amount of run out. :jawdrop:
So I'm hoping somebody can recommend a trusted shop in the greater St Louis MO area where I can take the crank and have the bearing and rod changed.
Or maybe I'm over-thinking it and any machinist could do it?
Edited by Whozaa
