2004 Won't Start? Carb? Compression? OTHER?
Choke pulled and kicking a lot.
Clean fuel, oil, etc...
It's run since I bought it but just for a day. (all the time we've had)
I've thought about taking it from the beginning and tightening it up and then going 1.5 +/- on the screw but I'm worried that the idle adjustment or whatever it's called) has been messed with. What if the carb is adjusted properly but the fine tuning 20 turns to the right or left?
Not knowing what the other person did, I have to start simple.
What would you suggest? Compression? Spark Plug?, etc...?
Thanks for the help!a
Edited by Shakeitdown
