fitting a piston to my piston .. advice plz
ktm 2013 350. Just fitting a ktm oem piston after 50hrs , i need a bit of advice as far as the oil ring is concerned . The spring that is fitted behind the oil ring seems to be to big and not letting the oil ring compress enough to go in the bore . I've checked the length of it compared to the one that was fitted and they are the same length. Is there something im missing ? Any advice greatly appreciated.
