what years fit in engine parts?
can someone tell me what years inner change. we just picked up a 05 for cheap. noticed it had a broken clutch cover and right side case under the water pump ,has a small crack, the guy JB welded it up. I was looking on ebay but not sure what years are the same.
also the clutch cable was really sloppy, had way to much fee play that couldn't disengage the clutch as a quick fix I just cranked the bolt on the clutch handle to take up the play, clutch works but is all the way out before it starts to engage. would that just be a cable adjustment? or is there something else I should look at?
we plan on taking the bike down over the winter but need to run it to find some of the things that need fixing.
thanks for any help
