Different Heads
Can somebody clarify the difference between the pre 95 and the post 95 cylinder heads please ? I know they fit on the same barrels and that the cams are dfferent. Does that mean that the cam cover is different ?  Is it the cam bearings that moved ?
I am thinking of fitting a later head on my 95 XR250R. Which has a cracked head.
Definitely changed the heads from 96 up. I have looked at both but not that closely. Unless someone chimes in with direct experience I would go with a 95 and below style head. They also didn't have any pre worn out valve problems due to the sharp intake lobs on the cam.
